RE: WOT- Servo Feedback
Of course, depending on the radio, you can always change the EP (end point) if computer. If not, then you will have to do this mechanically. You gotta remove that bind or your battery will not last very long.
Move the control rod closer to the center on the servo or further out on the control horn on the rudder, or both if needed. This will reduce the throw and hopefully remove binding.
CGr.
