Anyone have a Quick Time?
Anyone have a Phase3 Quick Time?
I got one the other day, and have made about 6 good flights, with one bad flight to start with.
It flies like a champ! After the stiffening of the horizontal and vertical surfaces, and adding some SFGs, this thing performed brilliantly. Hovering, inverted, spins, rolls, you name it, it can do it. The only trouble I'm having right now are with rolling circles. It's a bit harder to do them with this little plane, as there is very little side area. Maybee it's time for me to slow things down, and get into a bit higher alpha flight to attempt rolling circles?
And the rolling takeoff is like 3 ft. I don't even have to use 1/2 throttle to get the plane off the ground and into a hover.
Everyone seems to be complaining about their planes being warped, or damaged, or unglued, ect. Mine came with only the rudder glue joints slightly damaged, and were easily fixed with a bit of hot glue.
I think they need to make a V2.0 of these little EPP planes. Both planes need more side area, better controll surface mounts, like small pieces of plywood, and an extra carbon on the horizontal and vertical surfaces, not to mention a much more beefier landing gear mount, as mine broke on a slightly rough landing.
