RCU Forums - View Single Post - Kyosho CAP 232 Arrived.
Old 07-18-2003 | 01:44 AM
  #40
Michael_Flight
Default Cap and O.S. 50 SX
I finished the engine installation. I put in an O.S. 50SX. I put in the extra upward thrust recommended in the supplement.
If you look closely, you can see that I had to move the engine mount. When I first put it in I centered the mount, not the thrust line. I filled the holes by epoxying in a dowel. I then moved them over 1/4". All is well now.
I also found that a 2 1/4" spinner doesn't fit on the 50SX. I'll try a 2 1/2".
Next up is the pull-pull rudder.
-Michael
