RCU Forums - View Single Post - Super Tigre or Magnum?
Old 03-14-2008 | 11:48 AM
Warbird Joe's Avatar
Warbird Joe
Default RE: Super Tigre or Magnum?
ORIGINAL: FatOrangeKat
Well everyone talks about the "Ford/Chevy" debate; I have yet to see on on this site =) So, here's a Toyota/Honda, if you will...
I'm a newbie, and poor at that, so I need to pick on of these engines:
Super Tigre G51 Ringed
Super Tigre GS-45 ABC
Magnum XLS-46 ABC
While there are 2 sized of SuperTigre, they seem to put out about the same amount of power due to the differences in construction (ABC vs Ring).
I will be flying a Hobbico Nexstar (.46-.51), with my eyes on a .40-.50 low-wing sport plane for #2.
I don't know how this works, but if you can add any comments, all are encouraged and appreciated - I've heard about a leaky carb in the Magnum, then about the ST so leaky you can't shut it off.
Thanks!!!
Hello FatOrangeKat. Talking from experience here. I absolutely hate my Super Tigre 45. I spent much of my time at the field messing with that stupid engine than I did flying. I am not exaggerating at all about this, I go to the field for at least 5 - 6 hours when I go and spent about 20 minutes setting up, get the engine started and taxi out for it to stall when I turned to take off, bring it back start it up and repeat the stall. Then me and 3 -4 others would try to get that STUPID Filth Flarn Filth engine set and finally get it done and be able to fly it after a couple hours. Trust me this didn't happen because of lack of knowledge of the engine or experience of flyers. That engine was a nightmare. I have sent it back twice and it still does it. I can never go to the field and make a minor adjustment on the high end to meet the needs of adjusting temperatures. It is always that big of a nightmare. Then I got the Magnum 46 and it is a kitten. I purrs. Now I have definitely noticed the power is a much as the Super Tigre but man was the engine easy to break in. I have it since January and have only had to turn the high end up or down very sparingly do to weather. I absolutely swear by the Magnum. Now the only problem that I have with the Magnum is there are no seals on the muffler. So you have to buy some high temperature gasket maker from an auto store, about $5 a tube, and put it on the ends where the bolt goes in and comes out and where the two halves meet. Besides that, that is my only complaint. If you don't put that gasket maker on it you will be cleaning up a big mess. The muffler leaks like a stuck pig. So after my autobiography, lol, I highly suggest the Magnum.
