RCU Forums - View Single Post - Please Help on Building a Fliton Extra 330 Freestyle
Old 03-14-2008 | 04:02 PM
KWJ48's Avatar
KWJ48
Default RE: Please Help on Building a Fliton Extra 330 Freestyle
Mike, it seems your set up is more intended for a gasser. You don't need the loop. The line going from pick-up to carb will siphon possibly causing it to flood, or be hard to start. I never tried hemostats, the fuel lines were too hard to get to with the cowl on. On mine, the original tank outlet sat quite a bit above the carb slider, before I modified/lowered the tank mount.
