RCU Forums - View Single Post - which servos for goldberg ultimate?
Old 04-25-2003 | 03:16 PM
parkerspop
Default which servos for goldberg ultimate?
I am just about to the covering portion on my CG Bipe. And it is my first kit but I got some good help with my local hobby store. I only have one servo for the ailerons but it is the biggest one they recommended. and of course one servo for throttle, elevator and rudder. Your local hobby store can give you good rec. on what servoes to use.
I mounted the three servos by taking to pieces of 1/2" x 1/2" balsa and attaching the servos with elevator on the left, rudder in the middle as it is a pull-pull and throttle on the right. Then these were attached just behind the landing gear supports at the top of the plane.
Hope that helps, it seems to work well so far.
