RCU Forums - View Single Post - SCARY PROBLEM WITH NEW AR9100
Old 03-14-2008 | 08:20 PM
David Gladwin's Avatar
David Gladwin
Default RE: SCARY PROBLEM WITH NEW AR9100
Having complete success with 9000 Spektrum.
Received a new 9100 set up yesterday, rigged up today. Works fine , no smoke but one peculiarity. After binding caried out :
Switch on Tx, switch on Rx works fine , lights solid and connects.
Switch OFF rx with Tx remaining ON, switch Rx back on all amber lights flash but system seems to work.
If the Tx is switched off and the Rx is switched off switching the TX back ON and then switching the RX ON all connect and solid lights.
It does not matter which switch on sequence is used on the 9000, it still connects with solid lights. Is the 9100 different by design ?
Regards,
David Gladwin.
