RE: walbro WT carb question
The disk has a bevel, and should be fitted the right way so the bevel face can snug up to the bore. It takes some light fiddling with the setup to get it snug before you tighten the screw.
When fitted the right way, the disk cutout will be located where the idle jets are.
