RCU Forums - View Single Post - Cooling problems
Old 03-15-2008 | 03:32 PM
Sean Bowf's Avatar
Sean Bowf
Default RE: Cooling problems
I would try your cooling flow test on different components to see where the restriction is. Try it on the rudder, on the engine, then on the header cooler. Once you figure out where the restriction is, you can decide what to do to fix it.
Sean
