RE: Cooling problems
What kind of exhaust plate do you have?
Compare the size of the water fittings. Maybe they are too small or smaller than whats in the head of your engine.
If you can, take the fittings off the plate and see if you have build-up. If it is a flat plate style after-cooler you should be able to see clear through it easy.
