RCU Forums - View Single Post - Diff lube
Thread: Diff lube
Old 04-26-2003 | 04:31 PM
gubbs3
Default Diff lube
If your diff didn't slip when you tested it before you put it back into your truck you should be fine...if you tested it first. The wrong kind of lube will make the diff slip endlessly and melt the diff gear.
