RE: Voltwatch, you all use 'em?
I have one on every plane I own.
Loaded voltmeters are fine and I do own and use one but Voltwatch is a quick check every single flight plus it also verifies your switch and battery connections to your receiver are good, something a loaded voltmeter won't due simply because you are taking readings directly from the battery.
This is one, some times heated, topic. You will hear both opinions here.
