Fail safe ??????
well, if you read the posts, we are talking about loss of power, NOT signal. there is a difference between the two. loss of signal will still provide constant holding power to the servo. loss of power means there is no power to hold the servo and the spring will work. It works in mine and all the other cars i've seen. And like i posted before, if it is on the linkage, then the servo still has to pull on it all the time.
