RCU Forums - View Single Post - Fail safe ??????
Old 06-07-2003 | 06:46 PM
  #70
nitroman88
Default Fail safe ??????
IF your TRS can close the throttle when the RX is off then your servo will not last as long as it should, also you will drain more from your battery pack. IT indeed does put stress on your servo, anything that the servo has to pull is stress, in this case the servo would be suffering from lots of stress.
