RCU Forums - View Single Post - Help getting Radio and servos to work please
Old 03-16-2008 | 07:29 AM
kid chuckles
Default RE: Help getting Radio and servos to work please
Also sometimes with Futaba and a different reciever you have to use different plugs for stuff. Such as your ail. might plug into your throttle slot and your throttle into something such as elev. If this is the same system you had in an elec. it will not work. Your glow recievers are diff. from your elec. As they use the ESC to power your motor. They are just different. But would think that maybe you just need to change slots with your batt plug. Maybe leave an elev. plugged up and try moving the batt. plug into different slots and see if you can get one to work. Also I think you have to have a switch on your plane you don't want to leave your batt. plugged straight to your reciever. I guess you cleared the reciever with the radio to be able to input the new plane. Not just a whole lot that it can be. Hope you get it fixed. But if your taking it out of an elec. plane and trying to use in a glow it won't work. At least i don't think it will someone should know more about that than me though and maybe someone will post to confirm or not. Good luck.
