RE: O.S. .46 AX Replacement Bearings - remove shields?
The broken metal cage ultimately ends up as little fine metal particles and these come out from under the lip of the shield and seal also if that's the kind of bearing it is. These migrate up on the cylinder wall and gall the piston skirt and cylinder wall. Makes a mess.
As soon as you hear or feel the bad bearings, you should change them.
