RE: Butane Boost Injection
Nice find RedHarris
One problem with direct nitrous injection is when the nitrous is introduce there is no additional fuel introduced, this will run the motor lean! Unless you have the carb settings on the rich side all the time. This setup needs some way to add more fuel with the nitrous. I suppose one could fabricate a mirco venturi and tie it into the nitrous line and fuel tank. Hmmmm I will look into this.
