RE: which speed 400
well, I ran either 380 or 400 on dmd box. Elmode draws less current ..that s true, tehrefore less power. If you want more power and torque, or you need to do is increase the amps...but I dnt know with HLS....so the critical factor here is AMPS = amount of fuel going thru your engine taht gives you power.
