RE: Spectrum range in a supervee????
DSM requires you to have your TRANSMITTER antenna vertical... that is why the antenna has a swivel on it the bottom.
which ever way you hold the trans be SURE that antenna is pointing to the sky... if not and it is on a angle you will have very poor reception
