RCU Forums - View Single Post - Moki 2.1 Tuning Help
Old 03-17-2008 | 07:19 AM
DarZeelon's Avatar
DarZeelon
Default RE: Moki 2.1 Tuning Help
The low speed wheel is in the stock position...
OP,
I agree with Skiman about your 'break-in' being excessively long...
What determines the transition is the position of the fuel metering valve, which in the Moki's case means the rotary low-speed fuel control. If the engine cannot transition properly, with that control in the stock position, you must change it to a different position that will give you a good transition.
It is a simple as that!
How far is the fuel tank back from the carburettor?
You might need a pump/regulator, if it is not smack against the firewall...
