RE: First Gasser Newbie Questions
Did you dissamble the carb? Take the butterfly out? If you get it back in the wrong way, it won't idle. Take the spring off. It only adds resistance to the throttle servo. Most of these carbs I've seen will run on anything from 1.5 - .75 turns out on both needles. They're not usually touchy.
Dr.1
