ORIGINAL: Foamaholic
Yes I like the Optic a lot. Have had it for around 3 years. I have the synth module and it always worked, never a problem with it. The only thing I don't like is that sometimes the buttons and trim buttons don't work the first time I press them. I find it very easy to program.
Thanks. That helps me toward making a good decision on this. There are several reasons why I think I would like the Optic 6 a lot. I don't want to unnecessarily rule it out in making my choice.
Could be that some people just are not careful enough with removing and reinserting the RF module.... with gadgets made for a more niche market, you can't always assume that the devices are reasonably protected against rough handling like you would normally expect from a relatively costly device.
ORIGINAL: RCPilot100
..... I expect Futaba to eventually move to an integrated Tx down the road that is only 2.4 Ghz - so you cannot mix and match anymore. .....
Dan
I was just wondering what you meant with the mixing and matching. Mixing and matching what?
Cheers
