RCU Forums - View Single Post - Help needed in picking servos for V1 edge
Old 03-17-2008 | 10:11 PM
Tired Old Man
Default RE: Help needed in picking servos for V1 edge
If you've ever had a servo that did not center consistently you would find that it's a very big issue indeed. It's impossible to trim a plane with servos that do not center well. A very tight dead band is what makes good centering happen. A perfect example was the older Hitec 225mg. You could set a surface up any way you wanted and rarely see the same place twice with the servos at neutral. It can be pretty ugly.
