RE: Spring Air Advice (Patriot XL)
Well I got a little more done on mine last night. I finished sheeting up the bottom (still need to cut holes for the wire part). Also, I am modifying mine a little by putting both the flaps and ailerons inside the plane to reduce drag. You can see the oval ply pieces beside the retracts I'm going to use for the flaps.
