RE: alpha 60 cg way off
I mounted my RX battery halfway to the tail in the fuse. Also you might be able to replace an aluminum spinner with a plastic one to lighten the nose. I was able to move the engine toward the firewall about 3/4" and shed some tail weight. Maybe try a foam nose wheel instead of rubber?
There's a lot you can do, it just depends how far you want to go.
