RE: anyone in Vancouver B.C. Canada
I woudln't use wd-40 as after run oil, guys. After run oil is not necessary unless your planning on storing your car for awhile. I only put after run oil in if im going to store it for a month or more. To put the after run oil in just put some in the carb and turn the engine over. If you already used wd-40, i would make sure to let it all burn out completely before giving your motor any throttle the first time you fire it up.
