Thanks heaps dogman, it sounds all good in theory and I understand what you are saying, so now I'll just have to put it into practise, then I'll let you know how I went. I was nodding when reading your reply, yes I flooded the truck trying to start it when the value went on, cause I was use to how much I had to prime it before the value, but with the value, it obviously didn't need anywhere near as much priming. And yes, since the value the idle is a lot higher, wasn't that high prior to the value. So can i ask about the stalling issue, (before and after value installation) is that just cause it is running really rich and flooding at the moment?
Thanks heaps for your help Dogman
