Hydro-Lock!!!
Hello,
I was trying to start my H9 pts p51 yesterday and it didn't want to start i was using a new dubro spinner and prop and it seemed pretty snug to the fuselage compared to the stock 3 bladed spinner but i didnt think it would be a problem well i was using an electric starter so i didn't prime the engine at all and after about 3 minutes of trying to get her to start the engine totally locked. I can not move the prop whatsoever my question is how can i fix this if i can. I heard taking out the glow plug opening up the carb and try running the electric starter on it should work but i don't want to ruin my engine if i haven't already. Also if this is the correct method and it doesn't work am I SOL or are there other methods. Also what may have caused this could changing the spinner when its snug against the fuselage cause this?
Thank you for any help!
Brad
