RCU Forums - View Single Post - alpha 60 cg way off
Old 03-19-2008 | 12:42 PM
joco1
Default RE: alpha 60 cg way off
ive got it pretty close now thanks for everyones imput you can learn alot from you fellas and ladies !!! i wrapped my battery in foam before i put it on the dowel rod and when i pushed it back thru the fuselodge it filled the space around the batterry nicely i dont think it will move much now the way it sets the battery on a dowel rod worked perfect for me is this a new procedure or is a old trick of the trade???!!!
