RCU Forums - View Single Post - inverted engine
Thread: inverted engine
Old 04-26-2003 | 07:13 PM
armyrcer-RCU
My Feedback: (17)
Default inverted engine
have two questions for everyone. first i have an inverted os 46 la on a T.H. voyager is it normal to have fuel drip from the carb the fuel tank is a little higher than the carb but it will run fine at idle throttle all the way up to full. im thinking about a great planes quick fueler to put on because of the cowl would placing the quick fueler lower than the tank and even with the carb stop the fuel from dripping out before startup. second question is the c.g. mine is less than a 1/4 from the desired location is this ok. when the plane is setting still it will set on all three wheels but if i touch the back of the plane it will raise up of the nose wheel and rest on the back of the fuse any help would be great thanks mike
