RCU Forums - View Single Post - What does 120degree eCCPm mean
Old 03-19-2008 | 03:00 PM
Druss
Default RE: What does 120degree eCCPm mean
most ccpm are 120 deg, the disadvantage of 120 degree is that if you look at your heli from the side you'll notice that for elevator control the ball links from the aileron and pitch servos are much closer to the shaft than the front elevator servo, this creates uneven movement sometimes. 140 deg makes it so that all the ball links are at the same distance from the main shaft.
