Repeat after me... NEVER THIN EPOXY....NEVER THIN EPOXY...NEVER THIN EPOXY.... <<<repeat 1000 times......
Alcohol will change the chemical makup of the bond and change amount of strength of the bond... if you need thin epoxy (like this) take at least 60 minute epoxy, mix it, and hit it with a hair dryer/heat gun.. it will flow like water with no loss of bond strength... Alcohol is for cleaning up your tools/hands AFTER you have made the repair.
Dan
Carolina Custom Aircraft
