RE: revo 2.5 and 3.3 question
The differances are......Longer steering linkages, updated tranny cases (internals are the same), longer front driveshaft, P2 rockers, engine brace, 3.3 engine, wide ratio 2nd gear,and newer rims. Impact RC has a kit for $99.99 that comes with all the major parts to turn a 2.5 into a 3.3. Trans cases, dront driveshaft, engine brace, steering arms, body and chassis. Not a bad deal
You dont need the trans case but it has the positions to install the rear brake onto it. I you dont run a center diff then you dont need it.
