DOH!! TopFlite Screw up!!
I would basically scrap the web. I wouldn't use any kind of debonder. Just cut it off between the ribs and leave a little still attached. Then using a small, flat block sand off the excess.
Also, CA is the perfect choice for making mistakes like this. No chance to correct it. I suggest you consider using a good carpenter's glue in the future.
