ORIGINAL: Missileman
ORIGINAL: Wild Foamy
"Brokeback Mountain" springs to mind...
Woah, wait a minute there, your mind seems to be painting with a bit wider brush than most [X(]
a lot of you say that you use the $10 voltwatchers and that it would be too expensive to kit out all your planes, well go on ebay and you can find chinese copys for about $2 each (they are £3 over here) so you could get 3x as more units than you would with a voltwatch. and they actually work!
If you think about it, even $10 for a Voltwatch isn't all that much compared to the $500 or more people sink in to alot of their planes and realistically you only need a voltwatch on the airplanes your are flying. The $2 or $3 copies that you mention make it even more of a "why aren't you using them?" situation.
The cheap ones are probably the REJECTS from the Voltwatch production line. They're called "floor sweepings".
