RCU Forums - View Single Post - Climb's when I chop power
Old 04-28-2003 | 03:08 AM
furloughed ual's Avatar
furloughed ual
My Feedback: (31)
Default Climb's when I chop power
JLB, we have 3 of the Aeroworks Edge ARF's at my field and they are all set up wrong (severe balloning on final while chopping the throttle). We added about 2* (1/8" under the 2 bottom engine mounting bolts) of up thrust and the airplane finally flew like it should. Tthere is so much down thrust in all 3 from the factory, that when you would roll the plane inverted at 1/2 throttle and go to full throttle, it would climb.....Shim 1/8" under the 2 bottom engine bolts and the pitch changes will go away....Aeroworks dropped the ball on this one..........
