Difference between Ramtech & Dynamax
APTAR is absolutely correct in what he said.
The basic difference is the pitch of the blades. The Ramtech is higher pitch, therefore it will probably have a little less static thrust, but will produce higher velocity(speed)
Kinda like a 3.23:1 rear end gear(Ramtech) compared to a 4.11:1 (Dynamax)
I'm sure others can elaborate on this subject.
Regards, Johnny
BTW Either fan should work very well in your airframe.
