Ramtec Fan Info
Hi Gents
Just want to clarify some info on the Ramtec Fan unit:
- The Ramtec fan is designed around the OS 91 and uses all the available power from the engine to produce max thrust at a lower rpm.
- The Ramtec fan works extemely well with intake areas down to 85% of the swept fan area.
- The Ramtec comes with anti-vibration mounts built-in to isolate the fan from the air frame. Important to the longevity of the air frame and reduction of aircraft noise.
- The Ramtec fan produces approximately 12 lbs of thrust at 21000 rpm.
- Our price on the Ramtec is much lower than the Dynamax.
Enjoy,
Ed
