RCU Forums - View Single Post - Is there an alternative to the Tamiya muzzle flash unit.
Old 03-21-2008 | 07:32 AM
heavyaslead's Avatar
heavyaslead
Default RE: Is there an alternative to the Tamiya muzzle flash unit.
I have wondered about this too, as I would like to substitute a high brightness LED, which is cheap and readily available.
It would also be safer than the High Voltage unit.
I believe using a high output LED would make the high voltage unit unnecessary. I believe David would be the one to ask as he understands the DMD/MF signals well.
