RCU Forums - View Single Post - Exceed-RC Raptor G2 Keeps Spining
Old 03-21-2008 | 09:32 AM
  #33
Ybenjulkay2x
Default RE: Exceed-RC Raptor G2 Keeps Spining
[quote]ORIGINAL: yadac123
I ran into this problem before and I thought it's the gryo but it's not. The setting on the radio need to be set back to default. What happened to me was that the dip switch #12 was adjusted and I forgot the original setting so my gyro setting is lost. I'm in the process of getting the setting from the factory and I will post it here once I have it. A quick solution is to use another radio that the setting has not been adjusted and it will work again.
Andy
ORIGINAL: Ybenjulkay2x
i also have problem with my raptor g2 that i thought its the gyro ( keep on spinning ), but it's not the gyro nor the servo or setting the transmitter and gyro, xheli ask me to send the gyro but i'm glad i didn't do send it, i decide to get another walkera 36 for $129 only and test what's going on. I found that the problem was the transmiiter (radio), the servo not supposed to operate when you throttle up unless you move the stick to left or right, i even test it w/o the gyro in the heli. it's too late for me to find out whats wrong with it, only 30 days warranty and i don't want to be get charge for shipping/labor for a parts that works. at least i have parts for my raptor g2 as it was the same as the walkera #36, just slight diff. on its color
i bought the raptor g2 last Dec.for christmas, bought the walkera Feb. for my birthday. the raptor g2 work for about 3 weeks then it just start just spinning on me, uncontrolable, it won't take-off, every time i throttle it up, the servo for the tail just keep on engaging causing the heli to spin, i even notice that the servo arm swing full on a almost 1/2 way throttle (esc off) with or w/o the gyro. the remote of the #36 doesn't do it. so right now i use the walkera#36 remote.
[/quote
the setting of the walkera is v2 0% and v1 60% - 80% and also i bring the linkage in the servo arm of the tail closiest to the center
so i can adjust the gain more, less wagging. If you adjust the v2 your heli is just going to spin, see heli beginner forum and proceed to
the raptor g2 forum. alot of pilot talk about this heli. by the way the raptor remote is shut thats why i bought the walkera #36.
