RE: Nexstar Engine Mounting
I do believe that the offset is already set in the firewall, bit let someone else say for sure to be 100% cause I'm only 99% sure.
As for using thread lock I use BLUE thread lock on all of my rc stuff because you can remove the nuts and bolts after using blue rather than the RED, Si I would recommend only using the blue.
