RCU Forums - View Single Post - Honda GX 31 four stroke thoughts....
Old 03-21-2008 | 12:33 PM
Ralphbf's Avatar
Ralphbf
My Feedback: (27)
Default RE: Honda GX 31 four stroke thoughts....
You must keep in mind Cam timing and operating RPM.
You want everything to work together.
Huge intake passages deminish air speed and kill low and mid-range.
As far as the cam goes you could remone material off the back of the cam for more lift.
Your limiting factors would be:
Valve spring coil binding and Piston to valve clearance.
There is a lot of work involved doing these things.
I would start of with adding 15% nitro to my fuel.
You can pick some up at a go cart shop.
Remember always add nitro to gas, never gas to nitro.
A little gas in nitro is lets say unstable.
