RCU Forums - View Single Post - whats the effect of elevator-flaps mix in flight??
Old 05-01-2003 | 03:33 PM
fireflier
Default whats the effect of elevator-flaps mix in flight??
I have a Dazzler, and the flaps need to go opposite of what it would seem. You need to make the flaps go up when the elevator goes up, and vice versa. It seems backwards, but if you play with just the flaps, you will find that putting the flaps down makes the nose go down. In fact, I use flaps on mine, and I have up elevator mixed with down flaps to "trim" the aircraft to level flight when I mix the flaps. On the other side, I have down elevator mixed with up flaps to hold the nose level for airbrakes. Then on my mixer, I have up flaps mixed with up elevator (and vice versa) to make really tight loops.
