RCU Forums - View Single Post - whats the effect of elevator-flaps mix in flight??
Old 05-01-2003 | 04:33 PM
fireflier
Default whats the effect of elevator-flaps mix in flight??
funflyman,
you have to experiment with the ailerons on your cougar to see which way the make the nose go when you put them up and down. on the dazzler, both ailerons down makes the nose go down, so the ailerons are mixed to go up with up elevator to make the loops tighter.
