Bvm F-4
The Jet Cat P-120 will do a fine job for you if you are flying it clean. I currently have two BVM Phantom's on the board and will be putting P-160's in them when they are complete. Both aircraft will be fitted with the wing tanks and missiles, as well as mine carrying 6 500 pounders on the inboard pylons, so the drag is up. Hence the reason for the larger motor.
John Redman
Team BVM, Jet Cat USA
