A 4 or 5 mm. bolt will EASILY STRIP the threads in aluminum.Been there & done it.Had to get longer bolts.Just try it & you will strip the aluminum threads if you keep turning....no way will you shear the bolt head off.
BTW,I see in the other thread(hey,good pun huh?) that it's been done on a 3W 70.
