RCU Forums - View Single Post - where to fly
Thread: where to fly
Old 03-22-2008 | 11:21 PM
Speedfrek
Default RE: where to fly
It all depends on what you want to tear up also. If you don't mind tearing the siding off of the garage or cutting a hole in the drywall of the living room you can learn to fly in the house or between the house and the garage. But if you want to be safe then the field is the smartest place to learn. After you are good enough to make precision landings then the area is dependent on if the blades will spin or not.
