Engine idling
when you hit about 1/2 throttle or above you should see a thick blue smoke coming from the exhaust. if not you need to richen the lsn. It is not uncommon for lots smoke to not be coming from the ehaust at idle but if there isnt any, then you probably need richen the lsn alittle bit.
