EQ10, endpoints, and deflection.
Hi guys, looking for advice and opinions here. I have a WH Extra 300, a DX 7, JR921 rx, and 5955's around except for the rudder which is a single 8711, and an EQ10 with Turbo reg. I have set the center points on all channels so that they are the same for the correct channels. I haven't set the end points for any of the servos yet. I have a problem with my elevators in that I get more throw from the left half than I do on the right half, particularly on high rate at full deflection, maybe 5-6°. I haven't put a deflection meter on it yet, and I haven't checked the down travel yet. Would I correct this with the end point settings on the EQ10? The control rods are set to the same length. Thanks for all your help.
I should add that both elevator halves are on channel 3 on the rx/EQ10, with one side reversed. I am using throttle, ail,ele,rudder,choke,ail,smoke, so all channels are used.
