RE: Too much?
Yes i did change the stopper to a gas compatible one ( dubro tank ). I used Hayes neoprene line on the inside of the tank, is that ok or should i use tygon?
av8tor do you think having no muffler on could be part of the problem as yesterday the fuel system was fine ( other than the hole in the regulator )
